Hardware
14 TopicsRugged 4GLTE modem router
For people wanting to have the freedom traveling by Recreational vehicles and not wanting to sacrifice modern day life I'd loved to install a rugged device with the suitable power adapter. And a cool stuff would be to connect a rugged NAS to that device to stream videos and data to all the passengers!Router R7100P and AirCard 810 on USB3 ? (request upgrade)
Hello, I have a router R7000P and a AirCard 810(EUS)... Both are Netgear devices so I wished it can be compatible. Is it possible for the development team to make this router able to connect to the AirCard to increase the bandwidth (load balancing mode.... maybe bonding if it is possible?) in additionning the DSL (via ethernet) and LTE-A (via USB). Else it can be a very good way for a failover mode. Waiting for some answer. Maybe I'm not alone to want this kind of feature? Kind regards.12KViews0likes0CommentsNew features and security for modem and routers
Make id's protection and network Make vulnerability protection for all like Ports ,ip,dns,modem fimware, hardware ect make sure this feature don't drop the conection Make a internal software speed test Make Qos gaming for the modems c7000 don't have lan Qos Fix firewall false and positive and log Update wireless security to not be hack or decode by a haker using software to hack or bypass the security Fix the upnp security and network not detected upnp not reconise or not working corecly Increase nat and firewall speed to improve gaming performance and staviliity for faster loading Make dns protection prevent malware change dns or highjack the security Make secure login https for better security or higher Make a fimware protection to prevent hake es install malwere or nsa spy by modified the modem fimware Fix nat strict moderate or crashing fix that for gaming Fix port ward not opening the port or reconise Make nat fully compatible with other nat to play online Fix chanel frequency dropping for modem and wireless Make a new sistem to set voltage chanel power to 0 or any voltage so the modem module and reduce the voltage For better network performance ect Fix readyshare vulnerability this conect without you doing something fix that that happen on c7000 modem You can't disable readyshare fix that and when he conect don't show on conected device you can event block it in case is a haker Update always the firewall security so to be up to date for any security attacks on modem and routers Fix router and modem ip detect server dns and all the ip some time this cold get glish and the device may not work correctly Make a new test conection for modem and router incase there is a error or ip conflict ect Update the performance for all modem and all feature Make netgear software more faster so don't impact modem or raouer performance and staviliity for all Netgear don't forget always check for modem and router vulnerability they always have Just helping netgear corp make better product and security Thanks younew idea for netgear since they dont know anything about ipv6 at all so read this
i got an idea for the netgear team to invent a new modem that has 8 ports in back to conect stuff directly but no router and no firewall so that there firewall wont interfere with ipv6 at all this will completely solve there problem since its just a modem and 8 port thingy just sell it for something like $90 bux and they will sell like hotcakes after all we dont need any firewalls with ipv6 and no nat crap either that only was there to slow yr internet speed down thats 1 of the reasons i dont use software firewalls any more i need all the speed i can get for gaming and downloading stuff not for some dumb firewall to slow me down38KViews0likes2Commentsgreen products
I was wondering if router could be updatable, green and made it yours self? I'll explain, the device could be like a PC. Case Power converter Core router DSL or cable option antennas PLC module If one part fails there is only one part to change. Or if there is and hardware that evolve just change it. It could be interesting!!33KViews0likes2Commentsmake a new firewall settings
make a new firewall settings maake a profecional foresic firewall and strong level of security make to set diferent levelof security firewall off firewall low firewall medium firewall high firewall extreme security add turbo turbo firewall and nat aceleration x50 and no matter what security you set that you can play games with nope problem make to set rule or block any ip ,server,dns,,mac ect and firewall monitor you can see all trafic and pagake reach and attack or something rare or hakers try to break in ect add strong hardware encription 512bit or 1000bit or higther add new firewall encription.. encrip your network no matter what you go or what site your enter or sever ect and state secure and your network will always be encripted and will be more complicate to haker bypass the security fix firewall slowdonw when recive alot of junk over the network or attack or malware ect fix that the modem start slowdonw add strong https longin and ect everywhere reinforce webpage security https or trafics add strong anti exploit for all and new zero day attack make infected scrip blocking make infected cookie protection add for the first time adove flash protection to prevent any attack or hole or exploit fix the slowndow dos sistem and portscan when you play on gamming feel slow add deep protection scan dos and portscan ect add all this to support ip 6 too just helping38KViews2likes2Comments
