Kakashi2000's avatar
Dec 09, 2015
Status:
Unspecified
New features and security for modem and routers
Make id's protection and network
Make vulnerability protection for all like Ports ,ip,dns,modem fimware, hardware ect make sure this feature don't drop the conection
Make a internal software speed test
Make Qos gaming for the modems c7000 don't have lan Qos
Fix firewall false and positive and log
Update wireless security to not be hack or decode by a haker using software to hack or bypass the security
Fix the upnp security and network not detected upnp not reconise or not working corecly
Increase nat and firewall speed to improve gaming performance and staviliity for faster loading
Make dns protection prevent malware change dns or highjack the security
Make secure login https for better security or higher
Make a fimware protection to prevent hake es install malwere or nsa spy by modified the modem fimware
Fix nat strict moderate or crashing fix that for gaming
Fix port ward not opening the port or reconise
Make nat fully compatible with other nat to play online
Fix chanel frequency dropping for modem and wireless
Make a new sistem to set voltage chanel power to 0 or any voltage so the modem module and reduce the voltage
For better network performance ect
Fix readyshare vulnerability this conect without you doing something fix that that happen on c7000 modem
You can't disable readyshare fix that and when he conect don't show on conected device you can event block it in case is a haker
Update always the firewall security so to be up to date for any security attacks on modem and routers
Fix router and modem ip detect server dns and all the ip some time this cold get glish and the device may not work correctly
Make a new test conection for modem and router incase there is a error or ip conflict ect
Update the performance for all modem and all feature
Make netgear software more faster so don't impact modem or raouer performance and staviliity for all
Netgear don't forget always check for modem and router vulnerability they always have
Just helping netgear corp make better product and security
Thanks you
2 Comments
Comments have been turned off for this idea
  • switch from a dual core to at least a quad core no slower that 2 ghz and add more memory say about 4 to 8gb for the router or modem to allow them work better with parental controls on the router instead of a program on a computer or mobile device.
