Advanced Features
8 Topicsnew idea for security for all modem and raouters
update your security new inteligent firewall and monitor so you can see what is passing over the firewall and what is bloking in real time like attack ,junk,virus,scrips attack,dos,ddos,bots,malware,exploit bloking,portscan,domain infected,dns,ip ,devices ect IP spoofing attack dns poisoning attack arp poisoning attack tcp and upd port scaning attack protocol SMB attack protocol RPC attack protocol RDP attack Man in the middle attack Session hijacking Server spoofing Ping broadcast Ping of death Smurf Teardrop syn flood brute force ect so you can you can block any coonection with servers ,dns,ips,uknow device conected to the firewall,like hakers ,ect make allow rule or deny so you can deside what block or not or the same firewall tell you that is safe or not makenew ids protection and new gen intrution prevention ( fix all false and positive attack ) network monitor so you can block or deny network too of devices see all conection conected and full speed running so you can see what speed is running like 50mbs or more ect see ping and pakage lost and signal stable and see lag spike ect like for example xboxone or ps4 make new inteligent anti exploit protection protect from any exploit and zero exploit over the network or any new atack tech make memory protection ,protect from any attaack from memory modem or raouter make ready nas and share protection make usb protection make new anti dos or any attack wirless make anti jamming wirless for 2.4ghz and 5ghz prevent wirless drops and secure voice ect make a new turbo nat for gaming make new turbo firewall fix the dos and portscan and security make modem slow playing online games speed up the setting that dont affect gaming on any security setting scrip protection make anti bypass firewall make new unpnp protection make hhtps login and secure make dns protection make new gen turbo qos gaming set upload and download speed make a new modem or router speed test fix put the same ip on portward dont work fix that like example fist ip 192.168.10 for xbox second ip 192.168.9 for xbox in case the ip change dont let you fix that dont support mutiple ip make a new disnotic mode test security or vulneravility settings you have make new smart ip conflic fix make new uknow change have been made incase of hakers and what setting was change make turbo chanels for download and upload make to change upload and download frecuency make a new gen modem software for all make super fast software fix always disconection on modems for gaming make super fast cpu 4 core 2.20ghz or higth turbo for modem ect make gaming modem make smart porforward ports nope error and security make support ipv6 for portfoward and all settings like dns ip ect make to disable ready share for the modem add protection for printer security cold be vulnerable and easy for hakers make anti remote bypass and security wps security ect just helping30KViews7likes2CommentsNew features and security for modem and routers
Make id's protection and network Make vulnerability protection for all like Ports ,ip,dns,modem fimware, hardware ect make sure this feature don't drop the conection Make a internal software speed test Make Qos gaming for the modems c7000 don't have lan Qos Fix firewall false and positive and log Update wireless security to not be hack or decode by a haker using software to hack or bypass the security Fix the upnp security and network not detected upnp not reconise or not working corecly Increase nat and firewall speed to improve gaming performance and staviliity for faster loading Make dns protection prevent malware change dns or highjack the security Make secure login https for better security or higher Make a fimware protection to prevent hake es install malwere or nsa spy by modified the modem fimware Fix nat strict moderate or crashing fix that for gaming Fix port ward not opening the port or reconise Make nat fully compatible with other nat to play online Fix chanel frequency dropping for modem and wireless Make a new sistem to set voltage chanel power to 0 or any voltage so the modem module and reduce the voltage For better network performance ect Fix readyshare vulnerability this conect without you doing something fix that that happen on c7000 modem You can't disable readyshare fix that and when he conect don't show on conected device you can event block it in case is a haker Update always the firewall security so to be up to date for any security attacks on modem and routers Fix router and modem ip detect server dns and all the ip some time this cold get glish and the device may not work correctly Make a new test conection for modem and router incase there is a error or ip conflict ect Update the performance for all modem and all feature Make netgear software more faster so don't impact modem or raouer performance and staviliity for all Netgear don't forget always check for modem and router vulnerability they always have Just helping netgear corp make better product and security Thanks younew idea for netgear since they dont know anything about ipv6 at all so read this
i got an idea for the netgear team to invent a new modem that has 8 ports in back to conect stuff directly but no router and no firewall so that there firewall wont interfere with ipv6 at all this will completely solve there problem since its just a modem and 8 port thingy just sell it for something like $90 bux and they will sell like hotcakes after all we dont need any firewalls with ipv6 and no nat crap either that only was there to slow yr internet speed down thats 1 of the reasons i dont use software firewalls any more i need all the speed i can get for gaming and downloading stuff not for some dumb firewall to slow me down38KViews0likes2Commentsnetgear start making full support for raouter and modem ipv6 with full security
hi netger start making ipv6 why my server provider start working and they will soon upgrade to ipv6 and the modem i have c7000 have ipv6 but is not complete dont have dos and portscan on ipv6 start making full support the next modem you made for full ipv6 with firewall dos port scan and ect with full performance support for ipv6 and full security for ipv4 and ipv6 and start making modem with mode upload chanels my server provider have modem that support 16 upload chanels startmaking a modem with ( more upload chanels like 64 chanels and 64 download that support all chanels 1 gigabit both ot more extreme speed because is just stupid make one that have more that the another i like your modem beucase have better security..... that server provider modem always have bugs and bad performance just helping
