Kakashi2000's avatar
Mar 19, 2016
Status:
Unspecified
Make the next extreme gaming modem ideas
New modem and look software
New turbo 6 core cpu 2.40ghz to 3.60ghz or higher
Add new ddr4 1gb or high
Smart download channels for download and upload
Detect intereference, ,reAL time noise ,chanel dropping or cogeated, detect chanel speed performance and stability
New start frequency download and upload
Add upload correctable and snr
New speed test software
New turbo boost chanels download and upload
New ping reduction,and trafics network tech
Add 4 or 6 modem in one
New qos gaming aceleration set upload max and download max to full speed for xbox one or ps4
New network monitor see what speed are using all device like upload or download and show real speed and ping and package
New smart nat and upnp to open any port for gaming
New smart porforward and dmz and security
Some modem or router no mater what you use like dmz or ect don't let you join with other on the games
New add cox temp and signal temperature
Fix lan problem detecting device like xbox ect
Add new wireless anti jamming signal
Add new secure signal frame and wireless mac
New anti arp wireless haker can see wireless mac or sad and highijack
New wireless secure anti heardroping spy ect
New smart device bloking tech and remove it for lan and wireless
New smart 4 firewall dos,ddos,scrips attacks, virus,bots, malwere,brute force attack, ect
New anti mac clone, prevent hakers clone your mac
New https secure login tech
Add new dns protection
Add ip protection
Add ping protection
Add new smart nat privacy and protection
Add full compactly to join pole on games with out nat problems
Add to stealth mac device this prevent your mac be see
New smart port scan, deep scan that scan any new attack
Add attack map location
Add a new intrusion protection network and ids
Add upnp protection
Add to block any port on the firewall and ip that is running or if you want to block something is having acess or open ect
Add a new diasnostic smart mode this ,will check any error or conflict with the network, port ect and fix it
Add new firewall monitor ,add to see all port and ip all the device are running and you can block any conection or unblock
Example port 443 ,ip 0.0.0.0. Server ect block from having acess ect
Add new smart log ,for all attack
Add new attack level security like ,1 attack is low risk
2 atrack medium or high or extreme ect
Add new encryption modem prevent haker bypass the software ,firewall, logging, network to take control of the modem
Add new detect server trafics like say trafics server is low or high that cold impact performance ect
Add lan boost
Add turbo nat ,this nat speed running 80% or more faster that any other nat on the market fast speed
Add new channels 64 download and 64 upload
Add ready for fiber and cox
Ready for dosic 3.1 and all dosic
And ip and ip6
Add 8 lan and 4 fiber
Ect
Ready for the future and extreme ect just helping
Don't forget to fix dropping signal problems hardware cpu ect
1 Comment
Comments have been turned off for this idea
  • Add strong voltage dB resistance and strong noise cleaning
    That remove interference voltage judder, and static ect
    Add voltage protection
