The network map needs more work. The current version assumes that your primary network adapter is the subnet you want to scan. That is not always the case. We need an option to specify the subne...
cshackleton
Jul 14, 2016Observer
Also if you have multiple netgear routers on the network you can only apply paterntal controls to them individually.
My primary router is a d7000 and I have a wnr2000v5 upstairs to boost signal. But if I apply parental when connected to one device it doesn't percolate the network.
Annoying to have to set everything twice.
