The network map needs more work. The current version assumes that your primary network adapter is the subnet you want to scan. That is not always the case. We need an option to specify the subne...
Adewale
Jan 22, 2017Luminary
i will suggest you modify the topic of this idea to just read NETGEAR GENIE...the ideas you have submitted go beyond just the network map
I strongly support Idea 2!!!! the list of devices that connect to the router needs to stay on the router and made available to the genie apps while the genie apps only act as editors so that device names and types are consistent across the network. there's no reason why each genie app needs to generate its own list of devices
