jmchez
Mar 16, 2017Tutor
Status:
New Idea
Next Orbi Firmware must allow guests to see each other but not access Lan
The Orbi Guest Network settings has checkbox option for, "Allow guests to see each other and access my local network". These TWO options must be separated as other routers do. Others before me have ...
May 07, 2022Guru - Experienced User
Actually you might check out Orbi Pro versions of NG MESH. Most low end or home class systems like Orbi (non Pro) and MK systems do not support any VLAN Tagging on SSIDs. Most home users don't have a need for SSID VLAN Tagging. It's recommended that users first research and do there due diligence in to a prospective wifi system before buying something.
