Tonkinite's avatar
Tonkinite
Luminary
Apr 21, 2017
Status:
Engineering Investigation
Nighthawk Firmware Ideas
I have an X10, but I suspect most are applicable across models.
  • On factory reset, a button/tab to immediately upload the old config, on the first page.
  • Save the config file in a format that will make it forward/backward compatible.
  • Auto settings for the 5 GHz radios, with access to the UNII-2 and UNII-2 Ext bands.
  • Option to disable ALL the Basic UI panels/subpanels.
  • Weekly checks for firmware updates, generating a log message, etc., if such is available. Flashing the power light or something would be a good visual indicator.
  • UI needs rework, at minimum the eMail/TZ panels belong under the Administration section
2 Comments
