I just purchased a new Orbi RBS750 to add to my AX4200 System. I ran into the problem that seems to be common. It would not connect to my router. After a few frustrating days of searching for a solution (none of which worked for me). Almost every fix lead to updating the firmware. Which I could not do since the RBS750 would never connect to the router. After much trial and error I was able to resolve this myself. I am posting what I did here to hopefully help others.It may not work for everyone, but it worked for me.
Issue: RBS750 has a Pulsing White Light / Won’t Sync with Router / If hard wired to the router it was showing up in the Connected Devices list and not identified as a Satellite on the web interface tool. No way to update firmware.
- On a PC or Mac go to the downloads page on Netgear / Orbi site
- Download the latest firmware for the RBS750
- Extract the zip file to your desktop
- Reset the RBS750 to factory settings
- Connect it to Orbi CBR752 Modem / Router via CAT 5 or 6 cable
- Power up the RBS750
- On a PC connected to the Orbi network go to Orbilogin Web Interface
- Locate the RBS750, Mine was identified as a Connected Devices and not as a Satellite
- Make a note of its IP address
- On your PC open a new tab on your browser
- Go the theRBS750’s IP address – It may take a while to load up. Be patient.
- The web interface for the RBS750 Satellite should open
- Once it loads go to Update Firmware
- Select the upgrade file you extracted in step 3
- Upload the file to the RBS750
- Allow the update to complete and for the RBS750 to reboot
- After a few minutes it should sync with your Orbi Router and connect to the Orbi Network
- Remove the network cable
4 Comments
If your loading v7 FW on the RBS and trying to connect it to the CBR750, this will not work as the CBRs v4 FW is NOT compatible with v7 FW seen on RBS that get connected to a RBR750 series system which supports v7 FW. RBR750 and RBS750, this will work.
v7 FW loaded on RBS750s that connect to a CBR750 unit loaded with v4 FW will stop connecting and loose sync.
The CBR750 series only has v4 FW and there is no information if or when NG may support v7 FW on the CBR750. So users will need to keep v4 FW on both the CBR750 and ANY RBS750 that connects to a CBR750 series gateway to ensure the RBS maintain connections to the CBR.
All information regarding this is here including where to get v4 FW for the RBS750 series when connected to a CBR750 is found here:
There are many posts and information in regarding to updating RBS. Commonly known that all RBS need to be updated prior to a RBR unit being updated.
You should search the forums for this information and or post in the more appropriate forums to post, or seek help or additional information for better visibility by users.
Good Luck.
- chengsteinNovice
Signal boosting this post. Indeed, an RBS750 that came with a CBR750 has v4 firmware and will not connect as a satellite. After connecting the satellite wired, locating it in the network by IP, logging in with admin/password as login to upload the v7 firmware, the satellite immediately connected to the router that was hard wired. I didn't have to "add satellite" nor hit sync.
- avalynnTutor
Hey, this is gold — seriously, you just saved a ton of people from the same Orbi RBS750 sync nightmare. That pulsing white light and “shows up as a wired device but not a satellite” thing is super common, and the worst part is you can’t update firmware *because* it won’t connect. Classic catch-22.
Your workaround — factory reset, wire it up, grab its IP from the router’s device list, then manually flash the firmware through its own web interface — is **exactly** the kind of clutch move that should be in Netgear’s official guide. Most folks give up or RMA the unit when this happens, but you nailed it.
Quick tips to make it even smoother for others:
- If the IP isn’t obvious in the Orbi web UI, use a free IP scanner app on your phone or computer to find the satellite fast.
- Double-check that the firmware version on the RBS750 matches your CBR752 *exactly* after the update — mismatches are usually the root cause.
- Once it’s synced, consider turning off auto firmware updates in the router settings. Some of Netgear’s recent pushes have caused more problems than they fixed.This should be the go-to fix for anyone stuck in that loop. Appreciate you posting it — real community hero move. What made you think to try logging into the satellite directly? That’s the kind of out-of-the-box thinking that actually works.
- Pwbip3Novice
What would be the default admin/password for the additional add-on. I tried using my admin/password but it’s not taking accepting it. Can someone help me out. I followed the instructions up above. But getting an error to login using the IP address on the attached satellite.
