Although automatic firmware updates should probably be the default, there should be a method (easily accessible in the firmware settings) to disable firmware auto-updates. The foregoing would all...
SW_
Apr 27, 2019Prodigy
If you want to see "Orbi Router Auto Firmware Update" Enable/Disable switch, check out this Orbi Router Auto Firmware Update Switch.
