SimonGT007's avatar
Apr 13, 2018
Status:
New Idea
Please provide more 5GHZ wifi channel options - restricting to channels 36-48 is too limiting
I live in London in the UK and nearly every house nearby has wifi and growth of 5GHZ routers is growing rapidly - the WiFI explorer application on my Mac is picking up at least 13 wifi signals on channels 36-48 and around half of those have a signal strength of over 50% in my house.    But there are hardly any routers using the 52-64 channels.   Now I understand Orbi uses some of the 5GHZ channels for the backhaul, but surley there is enough space above channel 48 to support the backhaul and allow a 5GHZ wifi signal for devices so you can get a more reliable and stable connection on 5GHZ - which is the whole point of having a fast 'mesh' router as all my main devices support 5GHZ and I have a 200Mpbs broadband connection.  But the interference in the 5GHZ channels means my devices often default back to 2.4GHZ channels which kills the speed I can get down to around 50-70Mpbs vs the full 200Mpbs possible on the 5GHZ channel.
I used to have a Apple Airport Extreme and to be honest it could deliver a better 5GHZ signal throughout my whole house because it could use channels above 48 - and that was having the Airport on the ground floor and I live in a three-story house made of brick walls and the signal would reach the loft just fine!
Please Orbi team try and fix this as it is a major design flaw for most people in busy urban areas with lots of routers in the 5GHZ band - I don't really mind if it's a manual option or the Orbi is more intelligent and can automatically shuffle around use of the 5GHZ channels for the back-haul and wifi, but restricting use of wifi to just 4 channels makes the system no better than an Airport Extreme that is over 5 years old for my use case - hardly cutting edge performance as Negear claim and it is definately not living up to the marketing strap line of "Better Wifi. Everywhere"!
41 Comments
