Because of network topology it is often not possible to protect the router(s) device from internal (to the network) hacks or security compromises. Passwords are a good start. What would be a ...
AbhayB
Sep 16, 2017NETGEAR Employee Retired
Status changed:
Unspecified
to Resolved
Routers already have a failure count of 3 after which you have to either factory reset the router or use password recovery.
