akt111
Jun 10, 2020Tutor
Status:
New Idea
RAX45 — Nighthawk AX6 6-Stream AX4300 WiFi Router - Parental Controls
I purchased the RAX-45 router with an understanding that it will support some good parental controls, through the Nighthawk app as advertised under the below link. The link does not outline it very explicitly but the nighthawk app picture does show parental controls in the app. With such an expensive router and direction market is going, I expected this feature to be there.
https://www.costco.com/netgear-nighthawk-ax6-6-stream-ax4300-wifi-6-router.product.100523245.html
I reached out to the netgear support team asking if there is any other app or any other version that I need, in order to get the parental controls on this router but the response I received was, Circle Smart Parental Controls may support this in future but at this point there is nothing to support parental controls on this router and there is no ETA for support is there either.
Do we know if there would actually be CIRCLE app support for this router and if so any ETA for this update?
2 Comments
Comments have been turned off for this idea
