It would be nice if there is an option to separate the 2.4 GHz and 5GHz bands because the autolselect isn't working proppely on streets with havely crowded 2.4GHz band.
3 Comments
Comments have been turned off for this idea
- sclawrencApprentice
I agree 100%!!
- brucewboyerFledgling
I'm trying to separate the 5g and 2.4g and the instructions I found were to enable telnet. The nice video shows enable telnet on the router when you enter the 192.168.1.1 debug.htm. When I type it in it doesn't show enable telnet anywhere. Any ideas?
brucewboyer
I'm trying to separate the 5g and 2.4g and the instructions I found were to enable telnet.If you want help with your device, try posting in the section where they support it. This place is for product suggestions, not questions about how to separate the 5g and 2.4g.
