Suggest that the R7200 model of AC2100 support ReadyShare Printer.
2 Comments
Comments have been turned off for this idea
According to the manual, it does.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Check the section in the manual, Share a USB Printer. - PenetangFollower
Yes. The manual is incorrect. Unfortunately Netgear support has confirmed that this model does not support ReadyShare Printer and they will be revising the on-line manual.
