Santoku's avatar
Santoku
Follower
Dec 24, 2017
Status:
New Idea
Sorted "Attached Devices" for Orbi
Within the Orbi's web admin interface, the ability to sort the attached device list is conspicuously missing, yet very helpful for seeing what is going on at a glance. Most routers have this capacity. Essential user parameters would be to sort by IP address, connection type, or "connected orbi" i.e. sorted list of what's connected to the router, and each of the satellites, with the fixed listing being by IP address.
11 Comments
  • CrimpOn's avatar
    CrimpOn
    Yes, this  is correct..... when Access Control is Enabled. Not a major issue, because clicking the Turn on Access Control is not effective until that APPLY button at the top of the screen is selected.  Makes it a sort of "multi-step" process:
    • Select Advanced Tab.
    • WAIT for home page to appear.
    • Select Security.
    • Select Access Control
    • WAIT for device table to appear.
    • Mouse over column to sort on... click mouse.
    • Nothing happens... oh, yes. select Turn on Access Control
    • Mouse over columns again... click mouse.
    • Table sorts... and quickly, too.
    You are right, also, although sort of hidden (pun), it has been there all along.
