Netgear usb controll center does not work!!! When there will be an update for OSX El Captan????
37 Comments
- TrishSueNovice
Very frustrating that this does not work. I have recommended NetGear purchases to many friends and now we are all stuck without a working solution for too long. Need a date when this will be remediated
Come on Netgear - get a grip. Support your products.
- JimyNovice
I am also having the same issue getting a PhotoSmart network printer connected. Same error with El Captain installed on a mac of "Installation is incomplete! Please reinstall again" when trying to install USN control centre. Assuming if this problem has been around on this forum from Oct 2015 that it won't be resolved or supported? Just let us all know so we can buy some other product that facilitates what we need it to, and is supported.
still no solution?
- vinayklohitNovice
Any idea when would NetGear make this available? Been waiting since September now...Would appreciate if a solution is found on this asap..
months and months, still no update from netgear. keep up the good work fellas
- Never buying NETGEAR again.
- ElaineMNETGEAR Employee Retired
- cursedmysoulFollower
Hello,
I changed from Huawei Pocket Router to Netgear AC810
But it seems it wasn't worth it.. my problem here is i cannot USB tether to my Macbook Pro..
forget about OSX El Capitan, we upgraded to MacOS Sierra Ver. 10.12.4is there any solution for this? its been more then 3 year
- AbhayBNETGEAR Employee RetiredStatus changed:UnspecifiedtoResolved
This issue has been resolved. Please visit https://community.netgear.com/t5/General-WiFi-Routers/NETGEAR-USB-Control-Center-utility-for-MAC-OS-X-El-Capitan/m-p/1248440#M64974 for the solution.
