Damian86's avatar
Oct 01, 2015
Status:
Resolved
Update netgear usb control center
Netgear usb controll center does not work!!! When there will be an update for OSX El Captan????
37 Comments
  • USB controller 2.36 doesn't work with OSX Sierra . When will have an update
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    rick24 Based from our tests the utility is fixed and it is compatible to use with OS X Sierra.
    Can you provide us more information? Have you tried reinstalling the software?
  • I've installed twice It reconize the printer and work as it was really printing but it doesn't print when the process is finished nothing printed.My printer is an HPLaserjet P1005
  • I am using OS X Sierra also with a Dymo 4XL printer.  I am unable to download the USB Control Center software.  I would like to set up my ready share printing.  Please help.
  • I am running High Sierra os 10.13.  USB controller will not install completely.  When the application starts, I get a message that says that it is not installed completely and should be re-installed.  Multiple attemps to no avail.
  • I am running High Sierra os 10.13.2. Using the new NETGEAR USB Control Center 2.40, but same error of 2.36 version, get a message that says that it is not installed completely and should be re-installed. Multiple attemps to no avail. Please, any solution?!?! It's works very well for Windows System, but not in mac High Sierra! Thank you ver much!
