Hi
it would be exceptionally helpful if there could be some more verbose debug output for clients connecting/disconnecting to AP’s (both router and satellites) that indicate better troubleshoot information (eg signal strength, disconnected for reason x). By extension, if there are problems with the orbi mesh system connecting to one another (from interference / other reasons) it could go a long way to help identify how to fix it.
Happy to collaborate to see what a good outcome for this could be.
Thanks!
1 Comment
Comments have been turned off for this idea
Can try to capture debug logs and unpack the .zip file and check the files out. Many different things happening in the logs there.
