Knowledge Base Article
New - RAX35v2/38v2/40v2/41/42/43/45/48/50v1 Firmware Version 1.0.17.142 Released
Security Fixes: 6/06/2025
This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Download Links:
RAX35v2: https://www.netgear.com/support/product/RAX35v2
RAX38v2: https://www.netgear.com/support/product/RAX38v2
RAX40v2: https://www.netgear.com/support/product/RAX40v2
RAX41: https://www.netgear.com/support/product/RAX41
RAX42: https://www.netgear.com/support/product/RAX42
RAX43: https://www.netgear.com/support/product/RAX43
RAX45: https://www.netgear.com/support/product/RAX45
RAX48: https://www.netgear.com/support/product/RAX48
RAX50: https://www.netgear.com/support/product/RAX50
(RAX50/50s version 1 Only!)
To update your router’s firmware, follow the instructions in your router’s user manual.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
To Manually update FW on the router if this isn't seen on the routers web page:
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
This only supports models:
RAX35v2
RAX38v2
RAX40v2
RAX41
RAX42
RAX43
RAX45
RAX48
RAX50/50s - Version 1 Only.
Let us know how it works for you...Please leave feedback in a new post here: Nighthawk with WiFi 6 (AX) and WiFi 6E (AXE) Routers | NETGEAR Communities
Comments have been turned off for this article
