rax series
5 TopicsNew - RAX50v1 and 50v2 Firmware Versions Released
Security Fixes: This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security/ Download Links: Release Date: October 17, 2025 RAX50v1: RAX50 / RAX50S Firmware Version 1.0.17.144 Release Date: November 20, 2025 RAX50v2: RAX50v2 Firmware Version 1.1.6.38 To update your router’s firmware, follow the instructions in your router’s user manual. https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200 This only supports models only: RAX50v1 RAX50v2 Let us know how it works for you...Please leave feedback in a new post here: Nighthawk with WiFi 6 (AX) and WiFi 6E (AXE) Routers | NETGEAR Communities230Views0likes0CommentsNew - RAX41/42/50v2 Firmware Version 1.1.6.36 Released
Security Fixes: 7/01/2025 This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security/ Download Links: RAX41v2: https://www.netgear.com/support/product/RAX41v2 RAX42v2: https://www.netgear.com/support/product/RAX42v2 RAX50v2: https://www.netgear.com/support/product/RAX50v2 (RAX41,42 and 50/50s version 2 Only!) To update your router’s firmware, follow the instructions in your router’s user manual. https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200 This only supports models only: RAX41v2 RAX42v2 RAX50v2 Let us know how it works for you...Please leave feedback in a new post here: Nighthawk with WiFi 6 (AX) and WiFi 6E (AXE) Routers | NETGEAR Communities254Views0likes0CommentsNew - RAX70/78 Firmware Version 1.0.19.172 Released
Security Fixes: 6/11/2025 This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security/ Download Links: RAX70: https://www.netgear.com/support/product/RAX70 RAX78: https://www.netgear.com/support/product/RAX78 To update your router’s firmware, follow the instructions in your router’s user manual. https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200 This only supports models: RAX70 RAX78 Let us know how it works for you...Please leave feedback in a new post here: Nighthawk with WiFi 6 (AX) and WiFi 6E (AXE) Routers | NETGEAR Communities258Views0likes0CommentsNew - RAX35v2/38v2/40v2/41/42/43/45/48/50v1 Firmware Version 1.0.17.142 Released
Security Fixes: 6/06/2025 This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security/ Download Links: RAX35v2: https://www.netgear.com/support/product/RAX35v2 RAX38v2: https://www.netgear.com/support/product/RAX38v2 RAX40v2: https://www.netgear.com/support/product/RAX40v2 RAX41: https://www.netgear.com/support/product/RAX41 RAX42: https://www.netgear.com/support/product/RAX42 RAX43: https://www.netgear.com/support/product/RAX43 RAX45: https://www.netgear.com/support/product/RAX45 RAX48: https://www.netgear.com/support/product/RAX48 RAX50: https://www.netgear.com/support/product/RAX50 (RAX50/50s version 1 Only!) To update your router’s firmware, follow the instructions in your router’s user manual. https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200 This only supports models: RAX35v2 RAX38v2 RAX40v2 RAX41 RAX42 RAX43 RAX45 RAX48 RAX50/50s - Version 1 Only. Let us know how it works for you...Please leave feedback in a new post here: Nighthawk with WiFi 6 (AX) and WiFi 6E (AXE) Routers | NETGEAR Communities233Views0likes0CommentsNew - RAX29/30 Firmware Version 1.0.14.108 Released
Security Fixes: 4/04/2025 This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security/ Download Links: RAX29: https://www.netgear.com/support/product/RAX29 RAX30: https://www.netgear.com/support/product/RAX30 To update your router’s firmware, follow the instructions in your router’s user manual. https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200 This only supports models: RAX29 RAX30 Let us know how it works for you...Please leave feedback in a new post here: Nighthawk with WiFi 6 (AX) and WiFi 6E (AXE) Routers | NETGEAR Communities141Views0likes0Comments
