Knowledge Base Article
New - RAX50v1 and 50v2 Firmware Versions Released
Security Fixes:
This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Download Links:
Release Date: October 17, 2025
RAX50v1: RAX50 / RAX50S Firmware Version 1.0.17.144
Release Date: November 20, 2025
RAX50v2: RAX50v2 Firmware Version 1.1.6.38
To update your router’s firmware, follow the instructions in your router’s user manual.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
To Manually update FW on the router if this isn't seen on the routers web page:
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
This only supports models only:
RAX50v1
RAX50v2
Let us know how it works for you...Please leave feedback in a new post here: Nighthawk with WiFi 6 (AX) and WiFi 6E (AXE) Routers | NETGEAR Communities
Comments have been turned off for this article
