Knowledge Base Article
New - RS100/RS280/RS300 Firmware Version 1.2.7.4 Released
Release Date: June 2026
New changes:
- Adds cloud debugging support.
- Adds patch for WiFi stability.
- Changes the QoS bandwidth checking mechanism to avoid memory leak.
- Fixes FW-based Internet detection for App onboarding.
- Fixes IoT Network related issues.
- Fixes PPPoE detection fail during GUI onboarding.
- Fixes Hostapd issue for All RS-Routers.
- Fixes No Internet detected when connected directly to ONT device without WAN IP address received.
- Fixes ACL List not retaining Disconnected Devices and Showing Limited Entries in GUI.
- Fixes various security issues.
Download Links:
RS100: https://www.netgear.com/support/product/rs100
RS280: https://www.netgear.com/support/product/rs280
RS300: https://www.netgear.com/support/product/rs300
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support
Enter your model number in the search box, and click the Documentation button.
NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
To Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here:
Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there.
Thank you.
Comments have been turned off for this article
