rs series
13 TopicsNew - RS500/RS600 Firmware Version 1.2.7.2 Released
Release Date: June 11, 2026 Bug Fixes: Fixed various minor bugs. Enhancements: Improved installation flow. Improved NETGEAR Armor protection functionality. Improved QoS performance. Improved internet connection stability. Improved memory usage efficiency. Security Fixes: This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security Known issues: 3rd DNS WEB UI entry not displayed in web browser. NG is aware of this. Download Links: RS500: https://www.netgear.com/support/product/rs500 RS600: https://www.netgear.com/support/product/rs600 Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support Enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you. This article applies to: WiFi 7 (2) RS500 RS600 Let us know how it works for you. Please post in the Nighthawk with WiFi 7 (BE) | NETGEAR Communities Thank you.374Views0likes0CommentsNew - RS700S Firmware Version 1.0.11.8 Released
Release Date: June 11, 2026 Bug Fixes: Fixed an issue affecting the GUI and app speed test function. Download Link: https://www.netgear.com/support/product/rs700/#download Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you. This article applies to: Wireless BE Router Nighthawk (WiFi 7) (2) RS700 RS700S Let us know how it works for you. Please post in the Nighthawk BE series community here: Nighthawk with WiFi 7 (BE) | NETGEAR Communities Good Luck.245Views0likes0CommentsNew - RS100/RS280/RS300 Firmware Version 1.2.7.4 Released
Release Date: June 2026 New changes: Adds cloud debugging support. Adds patch for WiFi stability. Changes the QoS bandwidth checking mechanism to avoid memory leak. Fixes FW-based Internet detection for App onboarding. Fixes IoT Network related issues. Fixes PPPoE detection fail during GUI onboarding. Fixes Hostapd issue for All RS-Routers. Fixes No Internet detected when connected directly to ONT device without WAN IP address received. Fixes ACL List not retaining Disconnected Devices and Showing Limited Entries in GUI. Fixes various security issues. Download Links: RS100: https://www.netgear.com/support/product/rs100 RS280: https://www.netgear.com/support/product/rs280 RS300: https://www.netgear.com/support/product/rs300 Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support Enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you.376Views0likes0CommentsNew - RS700S Firmware Version 1.0.11.6 Released
Release Date: April 24, 2026 Bug Fixes: Fixed various security issues. Fixed an issue where wireless speeds were slow. Fixed various minor bugs. Enhancements: Improved wireless performance and channel selection stability. Added support for browsing the router's web interface via routerlogin.local. Improved router stability. Improved QoS function. Download Link: https://www.netgear.com/support/product/rs700/#download Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you. This article applies to: Wireless BE Router Nighthawk (WiFi 7) (2) RS700 RS700S Let us know how it works for you. Please post in the Nighthawk BE series community here: Nighthawk with WiFi 7 (BE) | NETGEAR Communities Good Luck.415Views0likes0CommentsNew - RS140/RS200v1/RS500/RS600 Firmware Version 1.0.6.22 Released
Release Date: April 13, 2026 Bug Fixes: Fixed various minor bugs. Enhancements: Improved router stability. Improved WAN Ethernet link interoperability. Download Links: RS140: https://www.netgear.com/support/product/rs140 RS200: https://www.netgear.com/support/product/rs200 RS500: https://www.netgear.com/support/product/rs500 RS600: https://www.netgear.com/support/product/rs600 Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support Enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you. This article applies to: WiFi 7 (1) RS140 Wireless BE Router Nighthawk (WiFi 7) (1) RS200 WiFi 7 (1) RS500 Wireless BE Router Nighthawk (WiFi 7) (1) RS600 Let us know how it works for you. Please post in the Nighthawk with WiFi 7 (BE) | NETGEAR Communities Thank you.432Views0likes0CommentsNew - RS140/RS200v1/RS280/RS300/RS500/RS600 Firmware Version 1.0.6.16 Released
Release Date: February 03, 2026 Bug Fixes: Fixed various security issues. Fixed an issue that could cause a kernel panic. Fixed various minor bugs. Enhancements: Added an IoT network function in the web user interface. Expanded Internet connection configuration options. Enhanced wireless stability. Improved WAN Ethernet link interoperability. Download Links: RS140: https://www.netgear.com/support/product/rs140 RS200: https://www.netgear.com/support/product/rs200 RS280: https://www.netgear.com/support/product/rs280 RS300: https://www.netgear.com/support/product/rs300 RS500: https://www.netgear.com/support/product/rs500 RS600: https://www.netgear.com/support/product/rs600 Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support Enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you. This article applies to: WiFi 7 (1) RS140 Wireless BE Router Nighthawk (WiFi 7) (1) RS200 WiFi 7 (2) RS280 RS280S WiFi 7 (1) RS300 WiFi 7 (1) RS500 Wireless BE Router Nighthawk (WiFi 7) (1) RS600635Views0likes0CommentsNew - RS700 Firmware Version 1.0.10.8 Released
Release Date: December 19, 2025 Bug Fixes: Fixed various security issues. Fixed various minor bugs. Download Link: https://www.netgear.com/support/product/rs700/#download Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you. This article applies to: Wireless BE Router Nighthawk (WiFi 7) (2) RS700 RS700S906Views0likes0CommentsNew - RS140/RS200v1/RS500/RS600 Firmware Version 1.0.5.22 Released
Release Date: October 15, 2025 Bug Fixes: Fixed a few minor bugs. Download Links: RS140: https://www.netgear.com/support/product/rs140 RS200: https://www.netgear.com/support/product/rs200/#download RS500: https://www.netgear.com/support/product/rs500/#download RS600: https://www.netgear.com/support/product/rs600/#download Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support Enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you. This article applies to: WiFi 7 (1) RS140 Wireless BE Router Nighthawk (WiFi 7) (1) RS200 Wireless BE Router Nighthawk (WiFi 7) (1) RS500 Wireless BE Router Nighthawk (WiFi 7) (1) RS600366Views0likes0CommentsNew - RS700S Firmware Version 1.0.9.16 Released
Release Date: October 20, 2025 Bug Fixes: Fixed various security issues. Fixed an issue that could cause IP assignment failures. Enhancements: Enhanced network service security. Download Link: https://www.netgear.com/support/product/rs700/#download Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you. This article applies to: Wireless BE Router Nighthawk (WiFi 7) (2) RS700 RS700S938Views0likes0CommentsNew - RS280/RS300 Firmware Version 1.0.5.18 Released
Release Date: September 30, 2025 Bug Fixes: Fixed various security issues. Fixed an issue that could cause slow internet upload speeds when the router is connected to some fiber internet service ONTs. Fixed an issue that could cause wireless internet speeds to randomly slow down. Fixed an issue that could prevent some USB devices from being detected. Fixed an issue that internet service providers may block a router due to too many broadcast packets sent from the router. Enhancements: Added a QoS function. Enhanced 5GHz wireless stability. Download Links: RS280: https://www.netgear.com/support/product/rs280/#download RS300: https://www.netgear.com/support/product/rs300/#download Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you. This article applies to: Wireless BE Router Nighthawk (WiFi 7) (2) RS280 RS280S Wireless BE Router Nighthawk (WiFi 7) (1) RS300497Views0likes0Comments
