rs series
10 TopicsNew - RS700S Firmware Version 1.0.11.6 Released
Release Date: April 24, 2026 Bug Fixes: Fixed various security issues. Fixed an issue where wireless speeds were slow. Fixed various minor bugs. Enhancements: Improved wireless performance and channel selection stability. Added support for browsing the router's web interface via routerlogin.local. Improved router stability. Improved QoS function. Download Link: https://www.netgear.com/support/product/rs700/#download Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you. This article applies to: Wireless BE Router Nighthawk (WiFi 7) (2) RS700 RS700S Let us know how it works for you. Please post in the Nighthawk BE series community here: Nighthawk with WiFi 7 (BE) | NETGEAR Communities Good Luck.121Views0likes0CommentsNew - RS140/RS200v1/RS500/RS600 Firmware Version 1.0.6.22 Released
Release Date: April 13, 2026 Bug Fixes: Fixed various minor bugs. Enhancements: Improved router stability. Improved WAN Ethernet link interoperability. Download Links: RS140: https://www.netgear.com/support/product/rs140 RS200: https://www.netgear.com/support/product/rs200 RS500: https://www.netgear.com/support/product/rs500 RS600: https://www.netgear.com/support/product/rs600 Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support Enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you. This article applies to: WiFi 7 (1) RS140 Wireless BE Router Nighthawk (WiFi 7) (1) RS200 WiFi 7 (1) RS500 Wireless BE Router Nighthawk (WiFi 7) (1) RS600 Let us know how it works for you. Please post in the Nighthawk with WiFi 7 (BE) | NETGEAR Communities Thank you.217Views0likes0CommentsNew - RS140/RS200v1/RS280/RS300/RS500/RS600 Firmware Version 1.0.6.16 Released
Release Date: February 03, 2026 Bug Fixes: Fixed various security issues. Fixed an issue that could cause a kernel panic. Fixed various minor bugs. Enhancements: Added an IoT network function in the web user interface. Expanded Internet connection configuration options. Enhanced wireless stability. Improved WAN Ethernet link interoperability. Download Links: RS140: https://www.netgear.com/support/product/rs140 RS200: https://www.netgear.com/support/product/rs200 RS280: https://www.netgear.com/support/product/rs280 RS300: https://www.netgear.com/support/product/rs300 RS500: https://www.netgear.com/support/product/rs500 RS600: https://www.netgear.com/support/product/rs600 Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support Enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you. This article applies to: WiFi 7 (1) RS140 Wireless BE Router Nighthawk (WiFi 7) (1) RS200 WiFi 7 (2) RS280 RS280S WiFi 7 (1) RS300 WiFi 7 (1) RS500 Wireless BE Router Nighthawk (WiFi 7) (1) RS600540Views0likes0CommentsNew - RS700 Firmware Version 1.0.10.8 Released
Release Date: December 19, 2025 Bug Fixes: Fixed various security issues. Fixed various minor bugs. Download Link: https://www.netgear.com/support/product/rs700/#download Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you. This article applies to: Wireless BE Router Nighthawk (WiFi 7) (2) RS700 RS700S728Views0likes0CommentsNew - RS140/RS200v1/RS500/RS600 Firmware Version 1.0.5.22 Released
Release Date: October 15, 2025 Bug Fixes: Fixed a few minor bugs. Download Links: RS140: https://www.netgear.com/support/product/rs140 RS200: https://www.netgear.com/support/product/rs200/#download RS500: https://www.netgear.com/support/product/rs500/#download RS600: https://www.netgear.com/support/product/rs600/#download Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support Enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you. This article applies to: WiFi 7 (1) RS140 Wireless BE Router Nighthawk (WiFi 7) (1) RS200 Wireless BE Router Nighthawk (WiFi 7) (1) RS500 Wireless BE Router Nighthawk (WiFi 7) (1) RS600328Views0likes0CommentsNew - RS700S Firmware Version 1.0.9.16 Released
Release Date: October 20, 2025 Bug Fixes: Fixed various security issues. Fixed an issue that could cause IP assignment failures. Enhancements: Enhanced network service security. Download Link: https://www.netgear.com/support/product/rs700/#download Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you. This article applies to: Wireless BE Router Nighthawk (WiFi 7) (2) RS700 RS700S892Views0likes0CommentsNew - RS280/RS300 Firmware Version 1.0.5.18 Released
Release Date: September 30, 2025 Bug Fixes: Fixed various security issues. Fixed an issue that could cause slow internet upload speeds when the router is connected to some fiber internet service ONTs. Fixed an issue that could cause wireless internet speeds to randomly slow down. Fixed an issue that could prevent some USB devices from being detected. Fixed an issue that internet service providers may block a router due to too many broadcast packets sent from the router. Enhancements: Added a QoS function. Enhanced 5GHz wireless stability. Download Links: RS280: https://www.netgear.com/support/product/rs280/#download RS300: https://www.netgear.com/support/product/rs300/#download Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you. This article applies to: Wireless BE Router Nighthawk (WiFi 7) (2) RS280 RS280S Wireless BE Router Nighthawk (WiFi 7) (1) RS300432Views0likes0CommentsNew - RS100/RS200v1/RS500/RS600 Firmware Version 1.0.5.12 Released
Bug Fixes: 8/06/2025 Fixed various security issues. Fixed an issue that could cause slow internet upload speeds when the router is connected to some fiber internet service ONTs. Fixed an issue that could cause wireless internet speeds to randomly slow down. Fixed an issue that could prevent some USB devices from being detected. Fixed an issue that internet service providers may block a router due to too many broadcast packets sent from the router. Enhancements: Added a QoS function. Enhanced 5GHz wireless stability. Download Links: RS200: https://www.netgear.com/support/product/rs200/#download RS500: https://www.netgear.com/support/product/rs500/#download RS600: https://www.netgear.com/support/product/rs600/#download Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support Enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you. This article applies to: Wireless BE Router Nighthawk (WiFi 7) (5) RS200 Wireless BE Router Nighthawk (WiFi 7) (1) RS500 Wireless BE Router Nighthawk (WiFi 7) (1) RS600677Views0likes0CommentsNew - RS700S Firmware Version 1.0.9.6 Released
New Features and Enhancements: 7/07/2025 Added a WiFi radio on/off function. Address Reservation on LAN Setup now allows multiple entries with the same Device Name. The Internet LED now blinks when there is traffic coming through the Internet port. Added Singapore CLS Level 1 support. Bug Fixes: Fixed various security issues. Fixed an issue that could cause slow internet upload speeds when the router is connected to some fiber internet service ONTs. Fixed an issue that could prevent remote office VPN connections from passing through the router. Fixed an issue with the Access Control function that could block some devices automatically after managing the settings from the router’s web user interface. Fixed an issue that could cause the DHCP server to assign the same IP address to multiple clients. Fixed an issue that could prevent some WiFi 7 clients from connecting using WiFi 7 on certain bands. Fixed an issue that could prevent BT TV streaming from working. Fixed a 5GHz WiFi connectivity issue. Fixed an issue that prevented IPv6 DHCP connections from working in some cases. Download Link: https://www.netgear.com/support/product/rs700/#download Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you. This article applies to: Wireless BE Router Nighthawk (WiFi 7) (2) RS700 RS700S570Views0likes0CommentsNew - RS150, RS280, RS300, RS500 and RS600 firmware Version 1.0.1.90 Released
Bug Fixes: 05/09/2025 Fixed various bugs. Download Links: RS150: https://www.netgear.com/support/product/rs100/#download RS200: https://www.netgear.com/support/product/rs200/#download RS280: https://www.netgear.com/support/product/rs280/#download RS300: https://www.netgear.com/support/product/rs300/#download RS500: https://www.netgear.com/support/product/rs500/#download RS600: https://www.netgear.com/support/product/rs600/#download Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here: https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there. Thank you. This article applies to: Wireless BE Router Nighthawk (WiFi 7) (1) RS150 Wireless BE Router Nighthawk (WiFi 7) (1) RS200 Wireless BE Router Nighthawk (WiFi 7) (2) RS280 RS280S Wireless BE Router Nighthawk (WiFi 7) (1) RS300 Wireless BE Router Nighthawk (WiFi 7) (1) RS500 Wireless BE Router Nighthawk (WiFi 7) (1) RS600935Views0likes0Comments
