Knowledge Base Article
New - RS100/RS200v1/RS500/RS600 Firmware Version 1.0.5.12 Released
Bug Fixes: 8/06/2025
- Fixed various security issues.
- Fixed an issue that could cause slow internet upload speeds when the router is connected to some fiber internet service ONTs.
- Fixed an issue that could cause wireless internet speeds to randomly slow down.
- Fixed an issue that could prevent some USB devices from being detected.
- Fixed an issue that internet service providers may block a router due to too many broadcast packets sent from the router.
Enhancements:
- Added a QoS function.
- Enhanced 5GHz wireless stability.
Download Links:
RS200: https://www.netgear.com/support/product/rs200/#download
RS500: https://www.netgear.com/support/product/rs500/#download
RS600: https://www.netgear.com/support/product/rs600/#download
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support
Enter your model number in the search box, and click the Documentation button.
NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
To Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here:
Let us know how it works for you...For more information, problems or issues found, please make a new post in the forums detailing your experiences. We'll help you out there.
Thank you.
This article applies to:
- Wireless BE Router Nighthawk (WiFi 7) (5)
- Wireless BE Router Nighthawk (WiFi 7) (1)
Comments have been turned off for this article
