× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Aircard 341u network registration (CREG) report denial although modem works ok.
Klinger
Working with the Netgear 341u on "Sprint" LTE network.
Problem I exprience is that although the modem seems to work with factory defaults (on NAT/IPT mode, Windows/Linux doesn't matter) , I'm issuing AT+CREG? and gets :
+CREG: 0,3
Which AFAIK stands for "3 - registration denied".
Here is some more AT commands output -
+COPS: 0,0,"Sprint Sprint",7
!GSTATUS:
Current Time:  2840             Temperature: 42
Bootup Time:   0                   Mode:        ONLINE
System mode:   LTE             PS state:    Attached
LTE band:      B26                 LTE bw:      5 MHz
LTE Rx chan:   8763             LTE Tx chan: 26763
EMM state:     Registered     Normal Service
RRC state:     RRC Connected
IMS reg state: No Srv
RSSI (dBm):    -73              Tx Power:    0
RSRP (dBm):    -95              TAC:         0F03 (3843)
RSRQ (dB):     -10              Cell ID:     01E05B1A (31480602)
SINR (dB):      1.4
Thanks.
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Aircard 341u network registration (CREG) report denial although modem works ok.
Hello Klinger
I am having this issue investigated might take a little time I will let you know what we found.
DarrenM
Message 2 of 3
Klinger
Thanks ! appreciate your help on this.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 5637 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
