Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Arlo Pro 2 Base Station Went Offline
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Setting up my arlo pro 2. One camera already recorded a 4second clip.. Then middle green light goes out. Power and camera still green. “Your base station is off line” . I turned off then on the base station but still only power and camera light are green. Middle light is still out.
Labels:
- Related Labels:
Troubleshooting
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
edmundojrbelen,
It sounds like your internet dropped or you are having an issue with your router communicating with the base station. Have you tried to reboot your router and test again? also, you can try to plug the base station Ethernet cable in to a different port of the router. There is a possibility of the Ethernet cable going bad as well.
Related Labels
Arlo Mobile App
503 -
Arlo Pro 2
11 -
Arlo Smart
153 -
Before You Buy
958 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,104 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,955
