Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Arlo Pro Base Station (VMB 4000) does not stay connected and drops out
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
My arlo base station will not stay connected. The center light is solid orange. Some times it will connect but then it will drop right out.
Labels:
- Related Labels:
Troubleshooting
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
That can be due to a bad port on the router or base or a bad cable. Swap cables and use a different router port. Also, reboot both the base and your router.
Related Labels
Arlo Mobile App
497 -
Arlo Pro 2
11 -
Arlo Smart
152 -
Before You Buy
956 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,101 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,940
