Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Arlo Q No connection
Reply
Discussion stats
  • 4 Replies
  • 1891 Views
  • 0 Likes
  • 2 In Conversation
snag
Trying to set up Arlo Q.  Problems with "discovering device".  "Taking to long to dicover, view set up instructions again"  "Unable to find your Arlo Q".
I reset, with the same results.  Trying to view with Iphone.
4 REPLIES 4
TomMac
Guru Guru
Guru
You said reset... but did you hold the reset for ten secs till the front led flashed ??
this usu solves the non-finding issue
Morse is faster than texting!
snag
HELD IN TILL FLASHING AMBER.
snag
I tried reset three times, till amber blinking LED.  No success.
TomMac
Guru Guru
Guru
Contact Netgear Support
