Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
recording arlo q
Reply
Discussion stats
  • 1 Reply
  • 2059 Views
  • 0 Likes
  • 2 In Conversation
wmilans
Follower
Follower
can i increase the lenght of the vidio clip recording time that is produced from the motion and audo detection. Im monatering a front door and a staircase. when the front door is opened and a person comes into view the recording doesnt last long enough for someone to get to the top of the stairs where the camera is positioned.
1 ACCEPTED SOLUTION
Accepted Solutions
TomMac
Guru Guru
Guru
Yes, in the MODE you are using, you can increase the fixed time to up to 2 mins and if motion continues up to 300 seconds
see ;https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-adjust-Arlo-video-recording-length/ta-...
Morse is faster than texting!
1 REPLY 1
TomMac
Guru Guru
Guru
