theali3n
Aug 31, 2016Aspirant
Drive drops out when doing timemachine
I have a ReadyNASRNDP400U which has 4 x ST2000DL003-9VT166 in RAID-X. Firmware Version: 4.2.28
I opened a ticket when my unit was under warranty and I don't believe I managed to get any help or info relating to my issue.
Whenever I try and do a TimeMachine backup to the NAS over gig ethernet where the device needs to run "high" bandwidth transfers from my SSD based Macbook Pro for some reason a drive, normally drive "3" drops out and I lose my redundancy. I have the device set to shutdown on drive error, so when I come back to check the unit is normally off and I have to pull the drive, reboot it and slide the drive back in, and it does a raid rebuilt. This seems to happen "every time" and I can't get a complete backup.
This doesn't seem to happen when the transfer is slower ie. if I try and do it over WIFI it seems to work/complete but takes forever. I have been able to reproduce the issue every time I attempt this, and it's been happening since I can remember. If the timemachine backup transfer goes >100mbits for any length of time, it seems to happen.
If I try and transfer a quantity of files at similar transfer speeds the unit seems to function properly, it seems like the issue relates to "fast" timemachine backups only.
I don't seem to be able to see anything when ssh'ing and poking around, so I thought I'd ask. I don't see any reason for it to be doing what it's doing, and again it only seems to happen when doing a TimeMachine backup.
Yes, the device is aged, yes the drives are aged, but the only time I can ever remember having to do a raid rebuild is when trying to do the backup as above.
Any suggestions or anything I can try would be most welcome.
Thanks
- mdgm-ntgrNETGEAR Employee Retired
Which disk firmware is on the disks?
There is a known issue with firmware older than CC3D. Disks with CC3C firmware can be upgraded to CC3D firmware, but disks with CC32 firmware cannot.- theali3nAspirant
Uggg....
storage:~# dmesg | grep "CC32"
ata1.00: ATA-8: ST2000DL003-9VT166, CC32, max UDMA/133
scsi 0:0:0:0: Direct-Access ATA ST2000DL003-9VT1 CC32 PQ: 0 ANSI: 5
ata2.00: ATA-8: ST2000DL003-9VT166, CC32, max UDMA/133
scsi 1:0:0:0: Direct-Access ATA ST2000DL003-9VT1 CC32 PQ: 0 ANSI: 5
ata5.00: ATA-8: ST2000DL003-9VT166, CC32, max UDMA/133
scsi 4:0:0:0: Direct-Access ATA ST2000DL003-9VT1 CC32 PQ: 0 ANSI: 5
ata6.00: ATA-8: ST2000DL003-9VT166, CC32, max UDMA/133
scsi 5:0:0:0: Direct-Access ATA ST2000DL003-9VT1 CC32 PQ: 0 ANSI: 5
Can you please post the links to read more about the known issue.
Thanks
- kohdeeNETGEAR Expert
Here's a link to an old thread where users complained about this issue 4 years ago.
