- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC2000 WAC124 Access Point Issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
I want to use my AC2000 WAC124 just as an extender from my house to my garden office via the Ethernet cable. So same BT network, same BT password.
Instead it keeps on showing the Netgear-1 wireless network on my PC and I can’t see the BT network to select.
I have enabled Wireless Access Point and applied but makes no difference - all i can see is the wireless network.
How do I just use it as an extender without having to connect to a different network each time i go into my office?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC2000 WAC124 Access Point Issue
You can change the default SSID from Netgear-1 to whatever SSID you want to be set.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks but it’s not the name - it’s about having one network through my house and office rather than at the moment, i have to disconnect from my house BT network and connect to the NETGEAR network in my office as I move between the two. I just want to extend the BT house network using the NETGEAR router, not create a new network
- Mark as New
- Bookmark
- Subscribe
- Permalink
So you configure the same SSID as in place on your BT router, and set the same security mode and passphrase, isn't it?
it's perfectly configurable - just no click and play.
