GH199's avatar
GH199
How to switch of the WLAN
Hello Community,
can anyone tell me how to switch off the WLAN of my router ? (FVS318N)
I logged into the router and did search for it in the menue, but I can´t find it.
Thank´s
BR
  • GH199's avatar
    GH199
    Mar 12, 2021
    Many Thanks schumaku !
    In the meantime I've found the solution. You have to do the following steps:
    Network Configuration >> Wireless Settings >> mark the Wireless Profile >> click on >> DISABLE
  • schumaku's avatar
    schumaku
    No idea. If you can't disable it, you might look for the ability to disable the beacon (hiding the SSID) and put up a random SSID and password so it does not interfere much with your whatever other wireless.
    • GH199's avatar
      GH199
ProSupport for Business
