- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Location Map for WAC730 Deployment
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have 5 WAC730 APs. I was looking for some general reccomendations for locating the APs to make a mesh with our WC7500 controller. I have seen similar maps for other brands.
How far apart to place them, coverage field (I assume spherical?). Mix of upstairs/downstairs... etc. etc. Something like the attached, but with spacing, etc.
Thanks,
Rod
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi martinav,
It will still depend on how you wanted the wireless range it can coverage.
You may also check the manual for WiFi Equipment Placement and Range Guidelines(page 13).
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi martinav,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Location Map for WAC730 Deployment
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
