- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WAC-510 VLAN to SSID Association on CIsco RV325
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I had been using Cisco APs until I found that a lot of them have a throughput problem. WAC-510 has better throughput and clustering works well for me. Only trouble I've had with it is getting different SSIDs associated with VLAN ID numbers on the Cisco router.
Here is the configuration:
Cisco RV325 Router
VLAN 1 - Default
VLAN 25 - Guest
VLAN 100 - Voice
VLAN 5 - Windows
VLAN 6 - Linux
WAC-510 Access Point
SSID 1 (Windows) --> VLAN 5
SSID 2 (Linux) --> VLAN 6
AP LAN Config
DHCP
Untagged VLAN 1
Management VLAN 1
Under that setup, the Windows SSID has Internet but the Linux SSID has no Internet. When I swap the WAC-510 with a Cisco AP, the different SSIDs both have Internet.
If I set the AP LAN config to static IP and uncheck the 8021.Q option (Untagged VLAN), then I become unable to reach the AP Login page on the static IP. Then I end up having to reset the AP to default setting.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
WAC5xx (WAC510, 505, 540...) all support VLAN<-->SSID mapping.
Most of the time, when we debug clients not getting DHCP. it will normally be due to some conf error upstream.
Coming to your network :
Router==TrunkPort(1,25,100,5,6)====Switch====TrunkPort(1,5,6) === AP ~~~SSID1-VLAN5~~~ Client
Can you check if the DHCP request packets are reaching your router
You can capture packets on the AP, download it to your PC and check the VLAN mapping of DHCP packets.
sameway you can port mirror switch/router and check on that too.
We need to see, if your router did get a DHCP request packet from client and responded. the switch has to tag the response back and send it to AP. then AP will be able deliver it back to the right client on the right SSID.
other basic things:
make sure WAC510 is connected to WAN/PoE ports.
WAC510 is in AP mode.
Cisco RV325 Router
VLAN 1 - Default
VLAN 25 - Guest
VLAN 100 - Voice
VLAN 5 - Windows
VLAN 6 - Linux
AP LAN Config
DHCP
Untagged VLAN 1
Management VLAN 1
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: WAC-510 VLAN to SSID Association on CIsco RV325
Assuming all the VLANs are 802.1Q and taged - except of the default VLAN - the WAC510 config looks OK to me.
@Vectro wrote:If I set the AP LAN config to static IP and uncheck the 8021.Q option (Untagged VLAN), then I become unable to reach the AP Login page on the static IP. Then I end up having to reset the AP to default setting.
This will re-configure the management VLAN ID for no longer accepting untagged frames and sending tagged frames. Have the default VLAN ID 1 set here?
When I have it right, the RV325 does run the default VLAN 1 untagged - that's why you loose the management access.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@schumaku wrote:Assuming all the VLANs are 802.1Q and taged - except of the default VLAN - the WAC510 config looks OK to me.
To your first point, yes, all of the VLANs are tagged except the default. I've also included a screenshot of the VLAN configuration. The WAC510 is plugged into LAN 5. Still, the SSID with VLAN 6 (Linux) has no Internet.
To your second point, do the AP LAN settings affect the Wi-Fi tagging, or is this part just for management?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Vectro wrote:To your second point, do the AP LAN settings affect the Wi-Fi tagging, or is this part just for management?
That's just for the explicitly listed management VLAN. The SSID<->VLAN association does make use of tagging regardless of that setting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks both of you for getting back to me.
I've attached my AP config. I made a mistake in my last post. I actually had The Windows SSID on VLAN 1 by mistake. When I set it to VLAN 5 (where it's supposed to be), it doesn't have Internet, either. That still tells us something, only VLAN 1 gets Internet on the WAC510. On the client device, both SSIDs fail with the error "Unable to obtain IP address". Again, works fine with a Cisco AP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Another screenshot of AP config continued from last post.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
WAC SSID-VAN config looks OK - works like this in many instances for us. Strange....
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
other basic things:
Cisco RV325 Router
VLAN 1 - Default
VLAN 25 - Guest
VLAN 100 - Voice
VLAN 5 - Windows
VLAN 6 - Linux
AP LAN Config
DHCP
Untagged VLAN 1
Management VLAN 1
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
It was the Ethernet port! I switched the wire from the LAN to the WAN port and Internet works on both segments!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Vectro
The fine WAC510 documentation does say on p.138:
Change the system mode to Router mode or AP mode
The access point can function in one of the following system modes:
- AP. Select the AP radio button to let the access point function with its router
functionality disabled. This is the default setting. When the access point is in AP
mode, connect the WAN PoE port of the access point to your network.,
Happy that you discovered the cabling issue - enjoy!
