Radworm's avatar
Radworm
Initiate
Jan 09, 2021
WAC104 setup. apologia.net asking me to reset password over and over and over again
I bought a brand new wireless access point to be used for WiFi coverage on one side of my house.  I followed all the instructions in the setup.  I am able to login in to the apologia.net site with username admin and password as password.  I keep getting a pop up message "aplogin.net says Please change the password!  I click OK and change the password and hit apply and it keeps doing it over and over and over again.  I have used my iPad with three different browsers (Safari, Brave, DuckDuckGo) and my Windows 10 laptop with Edge and Chrome.  Nothing seems to work.  This is out of the box setup.  I can't get past this to do any advance setup or firmware updates.  Any help please?
  • Radworm's avatar
    Radworm
    Jan 30, 2021
    Yes, I did.
    I called customer service.  I ended up getting it to work on my laptop using chrome also.  I was able to use www.aplogin.net.  Their software is glitchy.  Once you change the password the first time, you have to logout back out.  Then when you log back back in the second time you use the username admin and password is your newly created password (not password any longer).  I was able to login back in with no issues.  I was then able to access the ssid settings, change the network password, set up the time zone, etc.
    If you don't log back out after changing the password the first time, it will keep asking you to change it over and over and over.
    Hopefully someone will find this useful.
    Thanks
    Brian
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Radworm,
    Welcome to the community! :)
    Kindly try to clear the cache of the browser you are using or use Incognito mode in Chrome then try to access the web-GUI of the WAC104 again.  Check if the same problem will occur.
    DaneA
    NETGEAR Community Team
  • Hi Radworm did you manage to solve this issue?
    I had exactly the same and it drove me crackers!
    In the end I solved it by using the desktop PC, accessing the access point via the IP address from Chrome.  This time the password change took.
    • Radworm's avatar
      Radworm
      Initiate
      Yes, I did.
      Thanks
      Brian
ProSupport for Business
