hpe34's avatar
hpe34
Follower
Aug 18, 2024
WAX220 POE problem
I tried to connect WAX220 with HPE 1910-8G-PoE+ (180W) JG350A  swich but without success.
I can see "Insufficient Power. Check if AF power is connected instead of AT Power. Turned off both 2.4GHz and 5GHz radios. Connect AT/PoE+ switch for full operation." so I think there is some problem during PoE negotiation between switch and AP. Switch is connected to patch panel and distance between patch panel and AP is approximately two meters.
Output from switch :
LLDP local-information of port 3[GigabitEthernet1/0/3]:
Port ID subtype : Interface name
Port ID : GigabitEthernet1/0/3
Port description : GigabitEthernet1/0/3 Interface
Port VLAN ID(PVID): 1
Port and protocol VLAN ID(PPVID) : 0
Port and protocol VLAN supported : Yes
Port and protocol VLAN enabled : No
VLAN name of VLAN 1: VLAN 0001
Auto-negotiation supported : Yes
Auto-negotiation enabled : Yes
OperMau : speed(1000)/duplex(Full)
Power port class : PSE
PSE power supported : Yes
PSE power enabled : Yes
PSE pairs control ability : No
Power pairs : Signal
Port power classification : Class 4
Power Type : Type 2 PSE
Power Source : Primary
Power Priority : Critical
PD requested power value : 25.5(W)
PSE allocated power value : 25.5(W)
Link aggregation supported : Yes
Link aggregation enabled : No
Aggregation port ID : 0
Maximum frame Size: 10240
MED information
Media policy type : Unknown
Unknown Policy : Yes
VLAN tagged : No
Media policy VlanID : 0
Media policy L2 priority : 0
Media policy Dscp : 0
PoE PSE power source : Primary
Port PSE Priority : Critical
Port available power value: 30.0(w)
Could anyone know what can be wrong?
best regards
Jakub
No RepliesBe the first to reply
ProSupport for Business
