myseeu
Oct 01, 2020Follower
3 Upstream channels not locked
I was checking the channels on my CM700 because I had noticed my internet has been intermittently dropping recently, and I saw that only 5 of 8 upstream channels are locked.
How can I make sure that all 8 of my upstream channels are locked? I do not know much about routers/modems so any help at all would be greatly appreciated.
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
| 1 | Locked | ATDMA | 1 | 5120 Ksym/sec | 17300000 Hz | 43.0 dBmV |
| 2 | Locked | ATDMA | 2 | 5120 Ksym/sec | 23700000 Hz | 43.3 dBmV |
| 3 | Locked | ATDMA | 3 | 5120 Ksym/sec | 30300000 Hz | 43.5 dBmV |
| 4 | Locked | ATDMA | 4 | 5120 Ksym/sec | 36700000 Hz | 43.8 dBmV |
| 5 | Locked | ATDMA | 5 | 1280 Ksym/sec | 41200000 Hz | 44.3 dBmV |
| 6 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
Its fairly standard for only 3-4 of the upstream channels to be locked. I've never had more than 4 and I'm on a gigabit connection.
Is it causing issues?
Depending upon what your ISP supports for your upstream configuration, no all channels will be locked in. I have 50Mpbs up link and mine is only using 4 channels.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
myseeu wrote:I was checking the channels on my CM700 because I had noticed my internet has been intermittently dropping recently, and I saw that only 5 of 8 upstream channels are locked.
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 Ksym/sec 17300000 Hz 43.0 dBmV 2 Locked ATDMA 2 5120 Ksym/sec 23700000 Hz 43.3 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 30300000 Hz 43.5 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 36700000 Hz 43.8 dBmV 5 Locked ATDMA 5 1280 Ksym/sec 41200000 Hz 44.3 dBmV 6 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV
