John00's avatar
John00
AC1750 Smart WiFi Router(R6700v3) - Port Forwarding Not Working
For the AC1750 Smart WiFi Router(R6700v3)
Port forwarding is still not working.
I wish to create an open port to run a game from my computer.
Application: Fantasy Grounds
Port: 1802
Operation System: Windows 10
External IP: 73.50.200.XXX
Static IP Set Up: (results from ipconfig)
Connection-specific DNS Suffix . :
IPv4 Address. . . . . . . . . . . : 10.0.0.10
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 10.0.0.1
Exception made in Windows Defender Firewall: (see attachment)
In the NETGEAR Genie (http://www.routerlogin.com)
Advanced Tab > Advanced Set Up > Port Forwarding / Port Triggering
Selected : Port Forwarding
Added a custom service:
Service Name: Fantasy Grounds
Protocol: TCP
External Port Range: 1802
Internal Port Range: 1802
Internal IP address: 10.0.0.10
Clicked Apply
Service shows up on the list
With the "Fantasy Grounds" application running...
Went to: https://canyouseeme.org/
Error: I could not see your service on 73.50.200.XXX on port (1802)
Reason: Connection timed out
Outside users can not connect.
  • > For the AC1750 Smart WiFi Router(R6700v3)
       Firmware version?  Connected to what?
       Is that the IP address of the WAN/Internet interface of the R6700v3?
    ADVANCED > ADVANCED Home: Internet Port : Internet IP Address?
       Use of the "10.0.0.*" subnet suggests that you have another NAT
    router between the R6700v3 and your ISP (and that other router has your
    public address, "73.50.200.XXX").  The resulting "double NAT" would
    defeat your attempts at using port forwading on the R6700v3 to allow
    incoming connections from the outside world.
       The usual solutions to such problems involve using only one router
    (hence only one LAN subnet), perhaps with a wireless access point, and
    with any port forwarding configured on the one/only router.  Details
    would depend on your actual equipment inventory, configuration, and
    goals.
    • John00's avatar
      John00
      Thank you for your reply and time.
      Firmware Version: V1.0.3.66_10.0.50
      Path: Dell (Alienware) Laptop Wireles > Router > Netgear CabLEModem CM1000 > Coaxial Cable  - just one router
      WAN/Internet (Advanced > Setup > Internet Setup):
      Internet IP Address: Get Dynamically from ISP - Selected
      Down further on the screen and unchecked:
      Use Static IP Address:  IP Address: 73.50.200.XXX ( matches )
      • antinode's avatar
        antinode
        Guru
           That looks good.  Why your R6700v3 is using its alternate LAN subnet
        ("10.0.0.*") instead of its usual default ("192.168.1.*") remains a
        mystery, but that's not fatal in itself.
           The usual problems with this stuff are:
           1. Wrong external IP address (different from the port-forwarding
        router's WAN/Internet IP address).  (An intermediate NAT router, for
        example, could cause this.)
           2. Bad port-forwarding rule (wrong port(s), wrong target address --
        including a wandering target).
           3. Server not listening on the port-forwarding target system.
           4. External influences: ISP blocking, other firewalls, ...
           You seem to have eliminated "1".  So long as the target/server system
        stays at "10.0.0.10", "2" should be ok.  (An address reservation on the
        R6700v3 for that system would be a good idea.)
           That should cover "3", but an actual test would be reassuring.  Can
        you connect to the (game) server from some other (game client) system on
        your LAN using the LAN IP address of the server (10.0.0.10:1802)?  If
        not, then port forwarding won't enable a connection from the outside
        world.
           If the router feature called "NAT loopback" is working on your
        R6700v3 (which it should be), then you should also be able to connect to
        the (game) server from some other (game client) system on your LAN using
        the WAN/Internet IP address of the server (73.50.200.XXX:1802).
           If all that works, then you get down to "4".
           Does Windows know that "Fantasy Grounds" means port 1802?
        Presumably, Windows thinks of your R6700v3 as a Private connection, so
        Profile:All should be more permissive than you need.  But that's only a
        security risk, not something which would stop function.
           If local access to "73.50.200.XXX:1802" works, but outside-world
        access fails, then you may need to ask your ISP about it.
           Or, of course, the R6700v3 firmware could be defective, but I don't
        recall seeing oodles of similar reports for that model, which I'd expect
        if it had such a defect.
