woody_weaver's avatar
woody_weaver
Follower
Nov 20, 2023
admin interface doesn't support https?
Device is a CM1000v2 cable modem; hardware 2.02 firmware V10.01.07 and seems to be current.
I'm surprised that the admin interface is not TLS enabled, and that there is nothing listening on 443?  Is that intentional, or is have I made a mistake somewhere?  I suppose if the box becomes compromised I can always reset it, but it seems like this would be a basic IoT protection?
--woody
  • So Comcast recently revamped their my device info page and they said that the CM2000 as of now is not recommended for their network, neither is it approved for Next Gen Speeds. (mid split) I was wondering why this is so? They really dont give any information other than its not supported by them or Netgear anymore. However its sister, the CM2050V is supported for next gen speeds, and recommended.  I was wondering where the responsibility lies for this device to get approved for their network? The list is constantly updated as of now the CM2000 is not recommended.
    Even the Arris S33 is supported and recommended.
    PDF of supported and unsupported devices.
    https://assets.xfinity.com/assets/dotcom/projects/cix-4997_compatible-devices/2023.09.25%20Full%20List%20of%20Compatible%20Devices.docx-%20vF.pdf
    • FURRYe38's avatar
      Thats there "recommended" list.
      Its still compatible and supported under the "Full List of Compatible Devices" list.
      • strykerzr350's avatar
        strykerzr350
        Guide
        Sadly that means nothing to them, as far as they told me. The compatible and recommended list are completely different things. Until they add it to the recommended list, they wont support it by pushing firmware updates.
        Netgear seems to get the short end of the stick when it comes to modems I have seen.
    • Kitsap's avatar
      Kitsap
      Master
      Like FURRYe38 says, the list belongs to Comcast.  To even the casual observer, it is a work in progress.  The development has definitely not been linear.  It has zigged, zagged, and double backed in the few versions that have been released.  I would expect it to continue to do so for some time.
      If your Comcast area is one that has been upgraded, I can understand your being anxious to know.  If not, just wait as there will be a new list next month or sooner.
      • Topology's avatar
        Topology
        Virtuoso
        The absence of the NETGEAR CM2000 from the Xfinity list of recommended devices for the Next Gen Speed Tier may simply be a temporary situation, while Xfinity continues to rollout its multi-gig deployment in more Next Generation markets.  This is a work-in-progress....
      strykerzr350
      Guide
      Since Netgear never responds to tech support here, I think I will open a ticket with them to see where testing is.
      From what I hear, they have to play ball with the ISPs to get their modems certified for next gen speed tiers.
      • FURRYe38's avatar
        Let us know how that turns out.
