Orbi WiFi 7 RBE973
Reply
C6900 Modem Mode for Google Wifi
fatherofthr33
 I recenly purchased the Google Wifi system but it doesn't have any ether ports on the hub.  Should I just use the ports on the modem after setting it into Router only mode or do I need to go out and purchase a network switch to plug into the Google Wifi?
I have not setup the Google Wifi yet since I have my Arlo hub, Xbox, and FireTV connected to the C6900 currently.
Model: C6900|High Speed Cable Modem Router
Message 1 of 4
Guru
Re: C6900 Modem Mode for Google Wifi
Sonmething to ask Google about. Check the user manual for there product.
If it has a built in router already, you may want to put the C series modem in to modem only mode. As it already has built in router and wifi.
Message 2 of 4
fatherofthr33
I ended up setting everything up yesterday and the ports on the C series no longer function after putting it into modem mode so I had to go out and buy a switch.
Message 3 of 4
Guru
Yes that is by design.
So you'll need to put a switch behind the Google router if more ports are needed.
Good Luck.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 825 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
