× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
Reply
C7000 as Wifi router
Fredo8454
Tutor
Hi, I would like to know if it's possible to use the C7000 3.0 as a Wifi router only since I got the new Spectrum modem 3.1 and how to do it?
Thank you
Message 1 of 10
Accepted Solutions
Guru
Re: C7000 as Wifi router
what speeds do you pay for?
Might not need anything as it should still hit 600-800mbps on spectrum. the C7000 has a pretty solid modem and it might just be spectrum pushing you to upgrade.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 7 of 10
All Replies
Guru
there isn't a way.
there's a way to make it a makeshift access point but you'd still need a router to manage it then.
Message 2 of 10
Fredo8454
Tutor
I see, I guess I won't have choice but to buy a new router... Unless I keep my C7000 if it's possible, on the Spectrum mail it says that if the new modem 3.1 is not installed the service will be interrupted, but then I asked online and the guy told me that I can stil keep my C7000...
Message 3 of 10
Guru
Since the C7000 is only DOCSIS 3.0, the ISP maybe cutting off support for these versions of DOCSIS. 3.1 has been out for a while now. DOCSIS is working on 4.0 some where down the road. I would recommend probably ditching the C7000 and find you a 3.1 supporting modem only unit. Then get you a external wifi router system, RAX, XR, MK MESH or Orbi MESH system. You have more management over external wifi routers systems than built in modem gateways.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 4 of 10
Fredo8454
Tutor
I wasn't aware of that at all, thanks.
So I will look for a router and use the Spectrum modem I guess.
Message 5 of 10
Guru
Can do that or ask the ISP which NG CM series modem is supported by them and you could connect it. If you wanted to avoid any rental fees from the ISP.
Good Luck.
Message 6 of 10
Guru
Message 7 of 10
Fredo8454
Tutor
I asked Spectrum and the guy told me that the modem is for free but I could rent them the router.  I'm sceptical since it's written "leased" on the modem box...
Message 8 of 10
Fredo8454
Tutor
I only have the "Internet 100" (Speeds at 100 Mbps Free internet modem and no data caps).
Message 9 of 10
Guru
If all you have is 100-200mbps, the C7000 would handle it no problem. Upgrading modems isn't going to make the speed any faster since the bottleneck in speed isn't the modem.
But if you want to spend the extra money to upgrade, feel free. But you won't see much improvements in speed since that router can max out 100mbps no problem.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 327 views
  • 6 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
