Bhomz's avatar
Bhomz
Tutor
Feb 23, 2023
CAX30 5ghz issues
Woke up 3 days ago my 5ghz band constantly dropping need to reset the modem it will come back again run for about 40mins and drop again did a factory reset same thing happened only affects the 5ghz band and only affects android devices google devices, anything that runs androids OS ie security panel, and tvs, my PC works fine on 5ghz all the time without dropping issues, my ios devices will drop speed from 600mb to 10mb but still connected but you can feel the slow down of the connection
