Swol's avatar
Swol
Follower
Jun 25, 2024
CAX80 WIFI connectivity issues with manual button
Good day,
I have a Night Hawk CAX80 that I have been having issues with. I mainly use ethernet for all my connections but here and there I will use the WIFI. I use the manual button to turn on and off the WIFI on the front of the device. The issue I am having is once you turn on the WIFI it will connect to your phone automatically but the connection does not stay connected especially when making a phone call. It then takes a few minutes on the phone for the signal to come back then you have to manually connect to the WIFI, it will not connect back automatically. I have 2 different iPhones models and it does it to both of them. This whole process usually takes 5 minutes or more to be finally connect to where you can make a phone call. I have very poor cell service so I use WIFI over calling.
1 Reply
