nemtulea's avatar
nemtulea
CM1100 Downstream light blinking
I have a CM1100 Cable Modem with Xfinity and have giga plan with 1.2gb downloads and 35mb uploads. For some reason while back i started to get the second led from the top blinking witch is the "Downstream light blinking" led light. I have rebooted the modem, reset, also changed the slitter outside with the same one that xfinity technician put in, check the firmware for the modem witch looks to be the latest there is, also in the cable menu 192.168.100.1 it say status is good. Now not sure if there is a problem with the cables or the modem it self. Purchased the modem from costco around 2020-2021, somewhere there. I am attaching the stats if anyone can read those and can tell me what maybe my problem.
(Testing done with modem connected directly to my pc. I bypassed the wireless router.)
Video link with led blinking:
https://drive.google.com/file/d/1Wa-37tDItY3sx2eZFLIJC0R0qZBxkX_C/view?usp=sharing
My Wireless router i use is : ASUS RT-AX86U (AX5700)
Appreciated and thanks for your time.
  • FURRYe38's avatar
    Please post a copy and paste of the modems connection status and event log page.
    https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
    https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
    FYI, the CM1100 isn't rated for 1.2Gb ISP speeds on the down to the WAN ports are only 1000Mpbs supporting. Your ISP had a 1Gb plan up until 2022 then they did a split and came up with 800Mpbs and a 1.2 Gb plan. I highly recommend you ask the ISP to change you to the 800Mpbs plan.
    • nemtulea's avatar
      nemtulea
      TimePriorityDescription
      2024-01-08, 01:28:33Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:01:5c:7b:86:51;CM-QOS=1.1;CM-VER=3.1;
      Time Not EstablishedNotice (6)Honoring MDD; IP provisioning mode = IPv6
      Time Not EstablishedCritical (3)No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:01:5c:7b:86:51;CM-QOS=1.1;CM-VER=3.1;
      Time Not EstablishedCritical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      2024-01-06, 01:19:28Critical (3)No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:01:5c:7b:86:51;CM-QOS=1.1;CM-VER=3.1;
      2024-01-06, 01:19:21Critical (3)SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:01:5c:7b:86:51;CM-QOS=1.1;CM-VER=3.1;
      2024-01-04, 13:52:56Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:01:5c:7b:86:51;CM-QOS=1.1;CM-VER=3.1;
      2024-01-03, 02:50:54Critical (3)No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:01:5c:7b:86:51;CM-QOS=1.1;CM-VER=3.1;
      2024-01-03, 02:50:47Critical (3)SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=9c:c9:eb:71:c3:e8;CMTS-MAC=00:01:5c:7b:86:51;CM-QOS=1.1;CM-VER=3.1;
      Frequency start Value
      This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
      Starting Frequency
      <tabindex=-1>Startup Procedure</tabindex=-1>
      ProcedureStatusComment
      Acquire Downstream Channel507000000 HzLocked
      Connectivity StateOKOperational
      Boot StateOKOperational
      SecurityEnableBPI+
      IP Provisioning ModeHonor MDDIPv6 only
      <tabindex=-1>Downstream Bonded Channels</tabindex=-1>
      ChannelLock StatusModulationChannel IDFrequencyPowerSNR / MERUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
      1LockedQAM25620507000000 Hz-1.8 dBmV42.6 dB2577377500
      2LockedQAM2564405000000 Hz-2.0 dBmV42.7 dB2467243000
      3LockedQAM2565411000000 Hz-2.1 dBmV42.8 dB2466209200
      4LockedQAM2566417000000 Hz-1.9 dBmV42.9 dB2467803000
      5LockedQAM2567423000000 Hz-2.1 dBmV42.7 dB2468206300
      6LockedQAM2568429000000 Hz-2.0 dBmV42.6 dB2468588300
      7LockedQAM2569435000000 Hz-2.2 dBmV42.7 dB2468963300
      8LockedQAM25610441000000 Hz-2.1 dBmV42.7 dB2469315600
      9LockedQAM25611447000000 Hz-2.0 dBmV42.8 dB2469705300
      10LockedQAM25612453000000 Hz-2.2 dBmV42.7 dB2470068300
      11LockedQAM25613459000000 Hz-2.3 dBmV42.6 dB2470411700
      12LockedQAM25614465000000 Hz-2.4 dBmV42.5 dB2470812800
      13LockedQAM25615471000000 Hz-2.2 dBmV42.6 dB2471181500
      14LockedQAM25616477000000 Hz-1.9 dBmV42.8 dB2471554400
      15LockedQAM25617483000000 Hz-2.0 dBmV42.8 dB2471910700
      16LockedQAM25618489000000 Hz-2.2 dBmV42.5 dB2472321500
      17LockedQAM25619495000000 Hz-1.9 dBmV42.5 dB2472683900
      18LockedQAM25621513000000 Hz-1.9 dBmV42.6 dB2473012600
      19LockedQAM25622519000000 Hz-1.9 dBmV42.7 dB2473403900
      20LockedQAM25623525000000 Hz-1.9 dBmV42.6 dB2473788100
      21LockedQAM25624531000000 Hz-1.7 dBmV42.7 dB2474152400
      22LockedQAM25625537000000 Hz-1.9 dBmV42.6 dB2474563000
      23LockedQAM25626543000000 Hz-2.1 dBmV42.5 dB2474912300
      24LockedQAM25627549000000 Hz-2.3 dBmV42.6 dB2475275900
      25LockedQAM25628555000000 Hz-1.9 dBmV42.6 dB2475594400
      26LockedQAM25629561000000 Hz-1.8 dBmV42.7 dB2476035300
      27LockedQAM25630567000000 Hz-1.9 dBmV42.6 dB2476386300
      28LockedQAM25631573000000 Hz-2.2 dBmV42.5 dB2476763900
      29LockedQAM25632579000000 Hz-2.0 dBmV42.6 dB2477117900
      30LockedQAM25633585000000 Hz-1.9 dBmV42.6 dB2477327900
      31LockedQAM25634591000000 Hz-1.6 dBmV42.8 dB2477706700
      32Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
      <tabindex=-1>Upstream Bonded Channels</tabindex=-1>
      1LockedATDMA110400000 Hz51.8 dBmV
      2LockedATDMA216400000 Hz51.3 dBmV
      3LockedATDMA322800000 Hz51.0 dBmV
      4LockedATDMA429200000 Hz51.3 dBmV
      5LockedATDMA535600000 Hz51.3 dBmV
      6LockedATDMA1140400000 Hz52.0 dBmV
      7Not LockedUnknown00 Hz0.0 dBmV
      8Not LockedUnknown00 Hz0.0 dBmV
      <tabindex=-1>Downstream OFDM Channels</tabindex=-1>
      ChannelLock StatusModulation / Profile IDChannel IDFrequencyPowerSNR / MERActive Subcarrier Number RangeUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
      1Locked0, 1, 2, 348850000000 Hz-5.8 dBmV39.0 dB1108 ~ 298724898172245734660
      2Not Locked000 Hz0.0 dBmV0.0 dB0 ~ 4095000
      <tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
      1Not LockedUnknown00 Hz0 dBmV
      2Not LockedUnknown00 Hz0 dBmV
      Current System Time: Mon Jan 07 17:37:39 2024
      System Up Time: 0:09:46
