eXgU2q3NDNT3RTf's avatar
Dec 11, 2020
CM1200 - Only One Locked Upstream Bonded Channel
I have a CM1200 paired with Spectrum service running firmware version 1.02.01.
The modem reports only one locked upstream bonded channel.  I occasionally experience (seemingly random) disconnects, which is a problem during the work from home era.
A Spectrum tech spent a half-day at my location and came to the conclusion that the problem is with the modem.  He says the Spectrum-issued modem locks all four upstream bonded channels, whereas my modem locks only one.
I assume the service provider - hardware provider finger pointing is common.   How can I assess if I have a bad modem as per the Spectrum tech?
Startup Procedure
Procedure Status Comment
Acquire Downstream Channel765000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnabledBPI+
IP Provisioning ModeHonor MDDhonorMdd(4)
Downstream Bonded Channels (Partial Service)
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
1LockedQAM25632765000000 Hz4.3 dBmV41.7 dB00
2LockedQAM2561579000000 Hz2.1 dBmV40.3 dB00
3LockedQAM2562585000000 Hz2 dBmV40.4 dB00
4LockedQAM2563591000000 Hz2 dBmV40.4 dB00
5LockedQAM2564597000000 Hz2.2 dBmV40.4 dB00
6LockedQAM2565603000000 Hz2.2 dBmV40.5 dB00
7LockedQAM2566609000000 Hz2.2 dBmV40.4 dB00
8LockedQAM2567615000000 Hz2.3 dBmV40.6 dB00
9LockedQAM2568621000000 Hz2.5 dBmV40.6 dB00
10LockedQAM2569627000000 Hz2 dBmV40.4 dB00
11LockedQAM25610633000000 Hz2.2 dBmV40.3 dB00
12LockedQAM25611639000000 Hz2.6 dBmV40.6 dB00
13LockedQAM25612645000000 Hz2.9 dBmV40.7 dB00
14LockedQAM25613651000000 Hz2.8 dBmV40.7 dB00
15LockedQAM25614657000000 Hz2.5 dBmV40.6 dB00
16LockedQAM25615663000000 Hz2.9 dBmV40.9 dB00
17LockedQAM25616669000000 Hz3.1 dBmV41 dB00
18LockedQAM25617675000000 Hz3.3 dBmV40.5 dB00
19LockedQAM25618681000000 Hz3.2 dBmV41 dB00
20LockedQAM25619687000000 Hz3.4 dBmV41 dB00
21LockedQAM25620693000000 Hz3.3 dBmV40.9 dB00
22LockedQAM25621699000000 Hz3.5 dBmV41.1 dB00
23LockedQAM25622705000000 Hz3.8 dBmV41.1 dB00
24LockedQAM25623711000000 Hz3.9 dBmV41.2 dB00
25LockedQAM25624717000000 Hz3.7 dBmV41.1 dB00
26LockedQAM25625723000000 Hz3.8 dBmV41.2 dB00
27LockedQAM25626729000000 Hz4 dBmV41.4 dB00
28LockedQAM25627735000000 Hz4.4 dBmV41.7 dB00
29LockedQAM25628741000000 Hz4.1 dBmV41.5 dB00
30LockedQAM25629747000000 Hz4 dBmV41.4 dB00
31LockedQAM25630753000000 Hz4.2 dBmV41.5 dB00
32LockedQAM25631759000000 Hz4.5 dBmV41.8 dB00
Upstream Bonded Channels (Partial Service)
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
1LockedATDMA15120 Ksym/sec17600000 Hz47.3 dBmV
2Not LockedUnknown20 Ksym/sec17600000 Hz0.0 dBmV
3Not LockedUnknown30 Ksym/sec24000000 Hz0.0 dBmV
4Not LockedUnknown40 Ksym/sec30400000 Hz0.0 dBmV
5Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
6Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
7Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
8Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
Downstream OFDM Channels
Channel Lock
Status
Modulation /
Profile ID
Channel
ID
Frequency Power SNR /
MER
Active Subcarrier
Number Range
Unerrored
Codewords
Correctable
Codewords
Uncorrectable
Codewords
1Locked0 ,2159272000000 Hz2.1 dBmV41.4 dB628 ~ 3467239325623741560
2Not Locked000 Hz0 dBmV0.0 dB0 ~ 4095000
Upstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power
1Not Locked000 Hz0 dBmV
    • eXgU2q3NDNT3RTf's avatar
      eXgU2q3NDNT3RTf
      Yes sir.  There are no line splitters between the modem and ISP service box.
      In addition:
      - Tech replaced my RG-6 with his own.
      - Rebooted CM1200.
      - Factory reset CM1200.
      My event logs are filled with:
      - Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      - Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      * MAC addresses redacted.
      I doubt the modem is bad and welcome any additional options to explore.
      • FURRYe38's avatar
        Check with NG support to see if there are any options available to you. Ask about an RMA.
  • I had the same issue just last week and I can say it was not the equipment as I bought the CM1200 last month to replace an older nighthawk modem/router combo.  This entire time I thought the threshold of 52+ DBs was ok up to 57 DBs, but come to find out that that is the analog standard for Spectrum as explained by the technician Supervisor.  As soon as he pulled my modem's information he saw three upstream channels locked at 51.3, 51.0, and 51.8.  He said that at 52 DB on an all digital system is the threshold.  I live in NC where I guess it is all digital where I live.  The first tech that came out adjusted my upstream to 50 DBs readings, but then without being told after he left, the regional maintenance crew changed the levels for the entire area which then made my DBs go back to the readings I just mentioned before.  Then the Tech Supervisor called and pulled information from my modem after an entire day of complaining to tech support on the phone.  Simple fix too.  Your splitter on the outside of the home where the coax cable goes into the home has like 5 different connection spaces on it.  Two will be for input and output.  The other three will have different measurements for reducing the DBs on the line as I was explained.  I would suggest your tech work with the splitter as they know more about configuring the splitter to work perfectly.  All the tech supervisor did, was increase the measured reduction connection from -3 DB to -7 DB.  Now my three upstream channels are locked solid with a 47.3, 48.0, and 47.7.  A good cushion for staying under the maximum.  I subscribe for 400 Mb/sec download and 20Mb/sec upload and am reading 480 Mb/sec download and 80 Mb/sec upload tested with speedtest.net to AT&T in Mexico City, Mexico (I decided to test out of network to ensure that it is not just an in Spectrum ploy to tell me my speed is fast in the network).
    Oh and believe me I thought it was a faulty modem mixed with the Orbi Mesh Router.
    Hope all is good with you all and your systems are doing well.
    • FURRYe38's avatar
      Here were mine is with my ISP:
      ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
      1LockedATDMA15120 Ksym/sec36000000 Hz40.5 dBmV
      2LockedATDMA25120 Ksym/sec29000000 Hz39 dBmV
      3LockedATDMA55120 Ksym/sec22000000 Hz39.3 dBmV
      4LockedATDMA62560 Ksym/sec16000000 Hz38 dBmV
