Orbi WiFi 7 RBE973
Reply
CM400 Cable Modem Getting Very Hot
LanceS4803
I recently purchased a Netgear CM400 High Speed Cable Modem and noticed that it is operating at an apparently very high temperature.
The body of the modem itself is hot, especially on the bottom, in the center.  But, the coax cable connection on the back of the modem is almost too hot to touch.
Is this normal?
Is the unit defective?
Can this be the cause of constant modem resets?  (I'll be making a separate post about that issue.)
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: CM400 Cable Modem Getting Very Hot
Hello LanceS4803
Yes it shouldn't be that hot do you have your modem in a open area and not stuffed in a entertainment center with other electronics if so and its still getting hot I would swap it out at where you purchased it or contact Netgear support and have it exchanged.
DarrenM
Message 2 of 3
LanceS4803
Thanks Darren.
It is out in the open on a decktop, and also in it's stand to expose top and bottom.
Will swap it out.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 6089 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
