GrahamJohn777
Dec 04, 2020Aspirant
CM500 - Xfinity says the weak signal is due to my modem? I need to update the setting of the signal?
Hi All,
I moved house and after about a month the wifi signal gets weak a few hours after a reboot of the modem and router. I spoke with xfinity and they said they have trouble shooted everything from their side and that the problem is my Netgear CM500 modem. Apparently I need to update the settings?
Does anyone know what the problem is?
Thanks
GrahamJohn
There's no settings to update.
do you have a screen snip of the cable connections page and the modem logs? That'll show us the signal strenght.
Xfinity is great at saying "its not our lines" for the first round of troubleshooting.
If you do have any splitters, amplifiers, or signal attenuators in the coax line, i'd recommend removing them.
Check the coax for kinks, bad/cheap connectors, extended runs
Prefereably move the modem to right where the coax enters the home to prevent the wiring internal to the home being the issue.
- GrahamJohn777Aspirant
What speeds do you pay for?
Not the speedtest, the cable connections page.
