Orbi WiFi 7 RBE973
Reply
Can I connect coax cable router to ethernet socket (Sonic)
Stalerat
Follower
I bought NETGEAR Nighthawk Cable Modem WiFi Router Combo C7000 and it worked perfectly with Xfinity - I just plugged into the socket with coax cable.
I recently installed Sonic in my apartment and they provided me with female ethernet socket. So I cannot connect it to my router straightforward because it doesn’t have wan ethernet socket.
Is there any crafty way to connect my cable router to ethernet socket provided by Sonic? Are there any adapters available?
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 2
Accepted Solutions
Guru
Re: Can I connect coax cable router to ethernet socket (Sonic)
No and yes.
You can't connect the c7000 to your sonic service.
The C7000 has a modem only mode but not a router only mode.
but you can make the c7000 into a type of access point.
You'll still need something controlling the routing through.
there's a guide here if you want to try it.
https://community.netgear.com/t5/Cable-Modems-Routers/Can-I-use-a-C6300-cable-modem-without-cable-in...
Message 2 of 2
All Replies
Guru
No and yes.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1318 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
